Inleiding
This guide will go over how to replace the small circuit board in your device.
You will need to have a new circuit board to replace the old one with.
Be careful around the edges of the circuit board as they can be sharp and you could possibly cut yourself.
Wat je nodig hebt
Using a Phillips #00 screwdriver, remove the four 4mm screws located on the joystick circuit board underneath the top half of the controller.
Remove the orange flat cable by pulling the orange tab parallel to the circuit board.
Release the blue flat cable by lifting up the white latch with a spudger.
Één andere persoon heeft deze handleiding voltooid.
