Ga door naar hoofdinhoud
HP Touchsmart IQ506 Stand Replacement
Wat je nodig hebt
  1. HP Touchsmart IQ506 Stand Replacement, Unplug the power supply: stap 1, afbeelding 1 van 2 HP Touchsmart IQ506 Stand Replacement, Unplug the power supply: stap 1, afbeelding 2 van 2
    • Unplug the power supply from the system.
  2. HP Touchsmart IQ506 Stand Replacement, Remove the RAM door: stap 2, afbeelding 1 van 3 HP Touchsmart IQ506 Stand Replacement, Remove the RAM door: stap 2, afbeelding 2 van 3 HP Touchsmart IQ506 Stand Replacement, Remove the RAM door: stap 2, afbeelding 3 van 3
    • Unscrew the RAM door from the system. Use a Phillips #1 screwdriver. Once you do this, unclip it from the bottom and pull forward.
  3. HP Touchsmart IQ506 Stand Replacement, Screwdriver placement tip: stap 3, afbeelding 1 van 1
    • Authors' note: The driver used here is from the LEGACY Pro Tech toolkit that was discontinued in 2015 or thereabouts. This kit is no longer available new, and the driver had limited torque; however, it was all I had at the time. Use a standalone Phllips #1 driver (in tool list) if you are struggling with a multi bit driver.
  4. HP Touchsmart IQ506 Stand Replacement, Remove the stand: stap 4, afbeelding 1 van 3 HP Touchsmart IQ506 Stand Replacement, Remove the stand: stap 4, afbeelding 2 van 3 HP Touchsmart IQ506 Stand Replacement, Remove the stand: stap 4, afbeelding 3 van 3
    • Remove the stand from the system. Use a Phillips #1 screwdriver to loosen the 4 screws. The stand will be loose and easily removed.
Conclusie
Nick
93.686 Reputatie
59 handleidingen geschreven
Master Techs Lid van Master Techs
Community
327 Leden
1.700 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 360
