Ga door naar hoofdinhoud
HP Touchsmart 600 1052 CPU Replacement
  1. HP Touchsmart 600 1052 CPU Replacement, Remove back cover: stap 1, afbeelding 1 van 3 HP Touchsmart 600 1052 CPU Replacement, Remove back cover: stap 1, afbeelding 2 van 3 HP Touchsmart 600 1052 CPU Replacement, Remove back cover: stap 1, afbeelding 3 van 3
    • Nearly every screw in this computer uses a Torx bit, but they also have a slit that allows them to be removed with a flat-head screwdriver as well.
    • Flip the computer screen down, and flip the cover on the stand up.
    • Remove the screw and slide the panel down to remove the cover.
  2. HP Touchsmart 600 1052 CPU Replacement, Remove the stand: stap 2, afbeelding 1 van 2 HP Touchsmart 600 1052 CPU Replacement, Remove the stand: stap 2, afbeelding 2 van 2
    • Unscrew the 4 screws holding the stand to the computer and pull the stand down to remove it.
  3. HP Touchsmart 600 1052 CPU Replacement, Remove bezels (Part One): stap 3, afbeelding 1 van 1
    • Remove the bezel covering the ports
  4. HP Touchsmart 600 1052 CPU Replacement, Remove bezels (Part Two): stap 4, afbeelding 1 van 3 HP Touchsmart 600 1052 CPU Replacement, Remove bezels (Part Two): stap 4, afbeelding 2 van 3 HP Touchsmart 600 1052 CPU Replacement, Remove bezels (Part Two): stap 4, afbeelding 3 van 3
    • Pull up on the bezel from the bottom. As long as you are careful, you should be able to remove them without breaking any clips
  5. HP Touchsmart 600 1052 CPU Replacement, Remove feet: stap 5, afbeelding 1 van 1
    • Unscrew and pull the foot towards you. Repeat on other side.
  6. HP Touchsmart 600 1052 CPU Replacement, Remove DVD cover: stap 6, afbeelding 1 van 2 HP Touchsmart 600 1052 CPU Replacement, Remove DVD cover: stap 6, afbeelding 2 van 2
    • Pull up on the little tab and remove the DVD cover
  7. HP Touchsmart 600 1052 CPU Replacement, Remove back panel: stap 7, afbeelding 1 van 3 HP Touchsmart 600 1052 CPU Replacement, Remove back panel: stap 7, afbeelding 2 van 3 HP Touchsmart 600 1052 CPU Replacement, Remove back panel: stap 7, afbeelding 3 van 3
    • CHECK ALL THREE PHOTOS TO REMOVE ALL SCREW
    • Remove all 13 screws
  8. HP Touchsmart 600 1052 CPU Replacement, Remove back (cont.): stap 8, afbeelding 1 van 2 HP Touchsmart 600 1052 CPU Replacement, Remove back (cont.): stap 8, afbeelding 2 van 2
    • Pull up on the bottom of the panel and hinge it.
    • It will come off, set it aside
  9. HP Touchsmart 600 1052 CPU Replacement, Remove power cover: stap 9, afbeelding 1 van 2 HP Touchsmart 600 1052 CPU Replacement, Remove power cover: stap 9, afbeelding 2 van 2
    • Unscrew both screws and remove the cover
  10. HP Touchsmart 600 1052 CPU Replacement, Unscrew panel: stap 10, afbeelding 1 van 1
    • Unscrew the nine screws holding the panel in.
  11. HP Touchsmart 600 1052 CPU Replacement, Pulling off the cover: stap 11, afbeelding 1 van 1
    • Pull the cover towards the top left to remove it
  12. HP Touchsmart 600 1052 CPU Replacement: stap 12, afbeelding 1 van 1
    • Unscrew CPU fan
    • DO NOT TRY AND REMOVE THE FAN. THE HEAT PIPE IS ON TOP OF THE CPU
  13. HP Touchsmart 600 1052 CPU Replacement, Removing the CPU cooler: stap 13, afbeelding 1 van 2 HP Touchsmart 600 1052 CPU Replacement, Removing the CPU cooler: stap 13, afbeelding 2 van 2
    • Unscrew the plate over the CPU
    • It uses a small phillips head, one of the only non torx bits in the computer
    • After unscrewing the plate, flip the fan off of the CPU
  14. HP Touchsmart 600 1052 CPU Replacement: stap 14, afbeelding 1 van 2 HP Touchsmart 600 1052 CPU Replacement: stap 14, afbeelding 2 van 2
    • Unlock the socket and remove the CPU
Conclusie
Één andere persoon heeft deze handleiding voltooid.
NahDoesntExist
352 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 120
