Ga door naar hoofdinhoud
Inleiding
The HP TouchSmart 15-r015dx has a standard laptop motherboard.
Onderdelen
Geen onderdelen opgegeven.
  1. Turn off your laptop.
    • Turn off your laptop.
    • Ensure your laptop is off. Removing the battery while it is on may harm your laptop or yourself.
    • Flip over to view the bottom of the laptop in order to gain access the battery and the DVD±RW Drive.
  2. There are two battery release switches circled, slide both switches inward to release and remove the battery. There are two battery release switches circled, slide both switches inward to release and remove the battery. There are two battery release switches circled, slide both switches inward to release and remove the battery.
    • There are two battery release switches circled, slide both switches inward to release and remove the battery.
  3. There is one screw holding the DVD±RW Drive in place. Use the #00 screwdriver to remove the screw. There is one screw holding the DVD±RW Drive in place. Use the #00 screwdriver to remove the screw.
    • There is one screw holding the DVD±RW Drive in place. Use the #00 screwdriver to remove the screw.
  4. The DVD±RW Drive is here. Remove by gently pulling it straight out. After removal of the DVD±RW Drive, two screws are exposed and must be removed. After removal of the DVD±RW Drive, two screws are exposed and must be removed.
    • The DVD±RW Drive is here. Remove by gently pulling it straight out.
    • After removal of the DVD±RW Drive, two screws are exposed and must be removed.
  5. Using your Phillips #00 screwdriver, remove the two screws to loosen the fittings of the keyboard. One of the screws lies in the label.
    • Using your Phillips #00 screwdriver, remove the two screws to loosen the fittings of the keyboard.
    • One of the screws lies in the label.
  6. Flip the laptop over to view the top and lift the screen up. There are sixteen clips holding the keyboard in place. Gently pry up each clip using a plastic opening tool. Once all clips are loose, lift the keyboard from the computer. Do NOT pull the keyboard up more than 2-3 inches as there is a film-material connecting the keyboard to the laptop.
    • Flip the laptop over to view the top and lift the screen up.
    • There are sixteen clips holding the keyboard in place. Gently pry up each clip using a plastic opening tool. Once all clips are loose, lift the keyboard from the computer.
    • Do NOT pull the keyboard up more than 2-3 inches as there is a film-material connecting the keyboard to the laptop.
  7. There is a small black latch holding the film-material in place. Flip the black latch up to release the film-material. Once flipped up, simply pull the film-material out from the laptop to release the keyboard. There are tiny prongs on the ribbon; it must be carefully removed and upon re-installation the prongs must be lined up exactly in each tiny track in order for the keyboard to work.
    • There is a small black latch holding the film-material in place.
    • Flip the black latch up to release the film-material. Once flipped up, simply pull the film-material out from the laptop to release the keyboard.
    • There are tiny prongs on the ribbon; it must be carefully removed and upon re-installation the prongs must be lined up exactly in each tiny track in order for the keyboard to work.
  8. Flip the laptop over to view the bottom and remove the remaining screws from the bottom.
    • Flip the laptop over to view the bottom and remove the remaining screws from the bottom.
    • There are 2 screws located underneath the covers.
  9. Flip your laptop over to view top and open it. Remove the four screws and the two wires before removing the base of the laptop.
    • Flip your laptop over to view top and open it.
    • Remove the four screws and the two wires before removing the base of the laptop.
    • The metal prongs that wires fit onto stay attached to the computer and can be easily bent when trying to remove or place the plastic piece on to secure the wire. Also pay attention to how the plastic piece looks when you take them off (i.e. which side is up and facing out).
  10. Use your plastic opening tool to pry the base of the laptop off.
    • Use your plastic opening tool to pry the base of the laptop off.
  11. There are two screws holding the hard drive in place. Remove these screws. Remove the hard drive by pulling it to the right like shown. Remove the hard drive by pulling it to the right like shown.
    • There are two screws holding the hard drive in place. Remove these screws.
    • Remove the hard drive by pulling it to the right like shown.
  12. There are 3 screws holding the motherboard in place. Unscrew the screws to release the motherboard. Unscrew the screws to release the motherboard.
    • There are 3 screws holding the motherboard in place.
    • Unscrew the screws to release the motherboard.
  13. There are several wires that need to be disconnected from the motherboard. Remove the wires carefully. Remove the wires carefully.
    • There are several wires that need to be disconnected from the motherboard.
    • Remove the wires carefully.
  14. After removing all the wires, pull the motherboard out.
    • After removing all the wires, pull the motherboard out.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Christopher Gonzalez
175 Reputatie
1 Handleiding geschreven
USF Tampa, Team 16-4, Watkins Winter 2015 Lid van USF Tampa, Team 16-4, Watkins Winter 2015
USFT-WATKINS-W15S16G4
4 Leden
6 handleidingen geschreven
Één commentaar
I need to buy this motherboard online
How can i find it?
Ahmed Mohsen Brary - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 25
Altijd: 3,598
