Ga door naar hoofdinhoud
HP TouchSmart 15-r015dx Keyboard Replacement
Wat je nodig hebt
  1. HP TouchSmart 15-r015dx Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 2 HP TouchSmart 15-r015dx Keyboard Replacement, Keyboard: stap 1, afbeelding 2 van 2
    • Using your Phillips #00 screwdriver, remove the two screws to loosen the fittings of the keyboard.
    • One of the screws lies in the label.
  2. HP TouchSmart 15-r015dx Keyboard Replacement: stap 2, afbeelding 1 van 3 HP TouchSmart 15-r015dx Keyboard Replacement: stap 2, afbeelding 2 van 3 HP TouchSmart 15-r015dx Keyboard Replacement: stap 2, afbeelding 3 van 3
    • Flip the laptop over to view the top and lift the screen up.
    • There are sixteen clips holding the keyboard in place. Gently pry up each clip using a plastic opening tool. Once all clips are loose, lift the keyboard from the computer.
    • Do NOT pull the keyboard up more than 2-3 inches as there is a film-material connecting the keyboard to the laptop.
  3. HP TouchSmart 15-r015dx Keyboard Replacement: stap 3, afbeelding 1 van 3 HP TouchSmart 15-r015dx Keyboard Replacement: stap 3, afbeelding 2 van 3 HP TouchSmart 15-r015dx Keyboard Replacement: stap 3, afbeelding 3 van 3
    • There is a small black latch holding the film-material in place.
    • Flip the black latch up to release the film-material. Once flipped up, simply pull the film-material out from the laptop to release the keyboard.
    • There are tiny prongs on the ribbon; it must be carefully removed and upon re-installation the prongs must be lined up exactly in each tiny track in order for the keyboard to work.
Conclusie
Jacob Kleinsorge
2.129 Reputatie
5 handleidingen geschreven
USF Tampa, Team 16-4, Watkins Winter 2015 Lid van USF Tampa, Team 16-4, Watkins Winter 2015
USFT-WATKINS-W15S16G4
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 21
Altijd: 3,061
