Inleiding
Use this guide to replace a broken home button board.
Wat je nodig hebt
In the following steps, you will use a metal spudger to lift the front panel out from the rear case of your TouchPad.
As in the previous step, use a spudger to pry the front panel up from the rear case along its long edge on the volume button side of the TouchPad.
Continue to pry the front panel assembly up along the volume button side of the TouchPad until there is a gap between it and the rear case.
Use a plastic opening tool to pry the home button board off the adhesive securing it to the front panel.
Één andere persoon heeft deze handleiding voltooid.
