Ga door naar hoofdinhoud
HP Stream x360 11-p015wm Keyboard Replacement
Wat je nodig hebt
  1. HP Stream x360 11-p015wm Keyboard Replacement, Back Cover: stap 1, afbeelding 1 van 2 HP Stream x360 11-p015wm Keyboard Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Orient the laptop to have the back cover facing upwards.
    • Remove the four rubber pads located in each corner.
  2. HP Stream x360 11-p015wm Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Tool required: JIS #1 Screwdriver
    • Using the screwdriver, remove all of the exposed screws.
  3. HP Stream x360 11-p015wm Keyboard Replacement: stap 3, afbeelding 1 van 2 HP Stream x360 11-p015wm Keyboard Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    iFixit Opening Tool
    $1.99
    • Tool required: iFixit opening tool
    • Open the laptop and orient the keyboard facing upward.
    • Slowly wedge the opening tool into the gap between the keyboard and the back cover.
    • After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
  4. HP Stream x360 11-p015wm Keyboard Replacement: stap 4, afbeelding 1 van 2 HP Stream x360 11-p015wm Keyboard Replacement: stap 4, afbeelding 2 van 2
    $3.99
    • This is a good time to clean any accumulated dust or debris. Use this link on tips for cleaning.
    • Tool required: Tweezers
    • Carefully use tweezers to remove the audio jack connector from the motherboard.
  5. HP Stream x360 11-p015wm Keyboard Replacement, Motherboard: stap 5, afbeelding 1 van 1
    • Remove the six 6.5 mm Phillips head screws from the battery using the JIS #00 screwdriver.
  6. HP Stream x360 11-p015wm Keyboard Replacement: stap 6, afbeelding 1 van 3 HP Stream x360 11-p015wm Keyboard Replacement: stap 6, afbeelding 2 van 3 HP Stream x360 11-p015wm Keyboard Replacement: stap 6, afbeelding 3 van 3
    • Unplug the wire attaching to the battery to the motherboard using the tweezers.
    • Remove the battery.
  7. HP Stream x360 11-p015wm Keyboard Replacement: stap 7, afbeelding 1 van 2 HP Stream x360 11-p015wm Keyboard Replacement: stap 7, afbeelding 2 van 2
    • Remove the six 3.5 mm screws from the silver plate cover with screwdriver JIS #00.
    • Remove the silver plate cover.
  8. HP Stream x360 11-p015wm Keyboard Replacement: stap 8, afbeelding 1 van 2 HP Stream x360 11-p015wm Keyboard Replacement: stap 8, afbeelding 2 van 2
    • Remove the four 3.5 mm screws from the metal arm using the JIS #00 screwdriver.
  9. HP Stream x360 11-p015wm Keyboard Replacement: stap 9, afbeelding 1 van 3 HP Stream x360 11-p015wm Keyboard Replacement: stap 9, afbeelding 2 van 3 HP Stream x360 11-p015wm Keyboard Replacement: stap 9, afbeelding 3 van 3
    • Detach all remaining wires from the motherboard using the tweezers.
  10. HP Stream x360 11-p015wm Keyboard Replacement: stap 10, afbeelding 1 van 2 HP Stream x360 11-p015wm Keyboard Replacement: stap 10, afbeelding 2 van 2
  11. HP Stream x360 11-p015wm Keyboard Replacement: stap 11, afbeelding 1 van 2 HP Stream x360 11-p015wm Keyboard Replacement: stap 11, afbeelding 2 van 2
    • Remove the six 3.5 mm screws from the motherboard using the JIS #00 screwdriver.
    • Remove the motherboard.
  12. HP Stream x360 11-p015wm Keyboard Replacement, Keyboard: stap 12, afbeelding 1 van 2 HP Stream x360 11-p015wm Keyboard Replacement, Keyboard: stap 12, afbeelding 2 van 2
    • Remove the three 6.5 mm screws from the second screen hinge and metal arm using the JIS #00 screwdriver.
    • Remove the metal bracket.
  13. HP Stream x360 11-p015wm Keyboard Replacement: stap 13, afbeelding 1 van 1
    • Remove the two 3.5 mm screws from the small sideboard using the JIS #00 screwdriver.
  14. HP Stream x360 11-p015wm Keyboard Replacement: stap 14, afbeelding 1 van 2 HP Stream x360 11-p015wm Keyboard Replacement: stap 14, afbeelding 2 van 2
    • Use the blue plastic opening tool to pry up the silver keyboard cover.
    • Remove the keyboard cover.
  15. HP Stream x360 11-p015wm Keyboard Replacement: stap 15, afbeelding 1 van 2 HP Stream x360 11-p015wm Keyboard Replacement: stap 15, afbeelding 2 van 2
    • Remove the keyboard.
Conclusie
Megan Waxman
160 Reputatie
1 Handleiding geschreven
IUPUI, Team S2-G3, Stella Fall 2019 Lid van IUPUI, Team S2-G3, Stella Fall 2019
IUPUI-STELLA-F19S2G3
3 Leden
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 268
