Wat je nodig hebt
Orient the laptop to have the back cover facing upwards.
Remove the four rubber pads located in each corner.
Gereedschap gebruikt in deze stap:iFixit Opening Tool$1.99
Open the laptop and orient the keyboard facing upward.
Slowly wedge the opening tool into the gap between the keyboard and the back cover.
After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
Use the JIS J1 screwdriver to remove the 6.5 mm screws surrounding the battery.
