Ga door naar hoofdinhoud
HP Stream x360 11-p010nr Battery Replacement
Wat je nodig hebt
  1. HP Stream x360 11-p010nr Battery Replacement, Battery: stap 1, afbeelding 1 van 3 HP Stream x360 11-p010nr Battery Replacement, Battery: stap 1, afbeelding 2 van 3 HP Stream x360 11-p010nr Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • First, make sure the laptop is completely powered off and not charging to avoid electric shock.
    • Flip the laptop upside down then remove the seven 6.5 mm screws using a JIS J0 screwdriver.
    • Also remove the two 8.5 mm JIS J0 screws near the hinge of the laptop.
    • Peel back the two rubber feet near the hinge of the laptop to reveal and remove two more 8.5 mm JIS J0 screws.
    • The rubber feet near the speakers have no screws.
  2. HP Stream x360 11-p010nr Battery Replacement: stap 2, afbeelding 1 van 2 HP Stream x360 11-p010nr Battery Replacement: stap 2, afbeelding 2 van 2
    • After removing all the screws, slowly and carefully lift the back cover, exposing the internal components.
    • Be careful not to damage the blue strip when opening the back case.
  3. HP Stream x360 11-p010nr Battery Replacement: stap 3, afbeelding 1 van 3 HP Stream x360 11-p010nr Battery Replacement: stap 3, afbeelding 2 van 3 HP Stream x360 11-p010nr Battery Replacement: stap 3, afbeelding 3 van 3
    • Carefully detach the blue strip that connects the back cover to the internals.
    • Make sure the blue tab is facing upwards when reassembling.
  4. HP Stream x360 11-p010nr Battery Replacement: stap 4, afbeelding 1 van 3 HP Stream x360 11-p010nr Battery Replacement: stap 4, afbeelding 2 van 3 HP Stream x360 11-p010nr Battery Replacement: stap 4, afbeelding 3 van 3
    • Using the JIS J0 screwdriver, unscrew the 6.5 mm screws surrounding the battery.
  5. HP Stream x360 11-p010nr Battery Replacement: stap 5, afbeelding 1 van 1
    • Carefully remove the surrounding wire away from the battery
  6. HP Stream x360 11-p010nr Battery Replacement: stap 6, afbeelding 1 van 3 HP Stream x360 11-p010nr Battery Replacement: stap 6, afbeelding 2 van 3 HP Stream x360 11-p010nr Battery Replacement: stap 6, afbeelding 3 van 3
    • Lastly, unhook the clip connecting the battery to the motherboard by pushing it away from the slot.
    • At this point, everything should be disconnected, simply remove the battery. Be sure to maneuver around the wire that runs between the middle of the battery.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Abdulaziz Alkulaib
116 Reputatie
1 Handleiding geschreven
USF Tampa, Team S7-G4, Cagle Spring 2017 Lid van USF Tampa, Team S7-G4, Cagle Spring 2017
USFT-CAGLE-S17S7G4
4 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 23
Altijd: 3,758
