Ga door naar hoofdinhoud
HP Stream x360 11 -p015wm Back Cover Replacement
Wat je nodig hebt
  1. HP Stream x360 11 -p015wm Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 2 HP Stream x360 11 -p015wm Back Cover Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Orient the laptop to have the back cover facing upwards.
    • Remove the four rubber pads located in each corner.
  2. HP Stream x360 11 -p015wm Back Cover Replacement: stap 2, afbeelding 1 van 1
    • Tool required: JIS #1 Screwdriver
    • Using the screwdriver, remove all of the exposed screws.
  3. HP Stream x360 11 -p015wm Back Cover Replacement: stap 3, afbeelding 1 van 2 HP Stream x360 11 -p015wm Back Cover Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    iFixit Opening Tool
    $1.99
    • Tool required: iFixit opening tool
    • Open the laptop and orient the keyboard facing upward.
    • Slowly wedge the opening tool into the gap between the keyboard and the back cover.
    • After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
  4. HP Stream x360 11 -p015wm Back Cover Replacement: stap 4, afbeelding 1 van 2 HP Stream x360 11 -p015wm Back Cover Replacement: stap 4, afbeelding 2 van 2
    $3.99
    • This is a good time to clean any accumulated dust or debris. Use this link on tips for cleaning.
    • Tool required: Tweezers
    • Carefully use tweezers to remove the audio jack connector from the motherboard.
Conclusie
DaisyHaskell
701 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S1-G2, Valliere Fall 2018 Lid van UMass Dartmouth, Team S1-G2, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G2
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 416
