Wat je nodig hebt
Unscrew all the screws on the back of the laptop and remove the cover
Same process and keep melting the rest of the plastic rivets after the metal cover. This can easily going over 2 or 3 hours if you are not quick enough.
And if everything goes alright, you might eventually get the problem keyboard removed and put a new keyboard back in.
then, use your solder station the melt the plastic back to the keyboard.
Bijna klaar!
Conclusie
