Wat je nodig hebt
Lift up on the small black tab at the connection point to unlock the flex ribbon cable using the tweezers.
Carefully pry up the gray metal piece on the end of the flex ribbon cable using tweezers.
Carefully remove the battery connector from the system board using the tweezers.
Één andere persoon heeft deze handleiding voltooid.
