Ga door naar hoofdinhoud
HP Stream 8 Motherboard Replacement
Wat je nodig hebt
  1. HP Stream 8 Motherboard Replacement, Midframe: stap 1, afbeelding 1 van 1
    • Use your nail or a spudger to pry the back cover off of the device.
  2. HP Stream 8 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Slide your finger around the rest of the back cover, lifting it completely off of the device.
  3. HP Stream 8 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Remove ten Phillips #00 screws from the inside cover.
  4. HP Stream 8 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Pry up the inside cover the same way as in the first step.
  5. HP Stream 8 Motherboard Replacement, Front-Facing Camera: stap 5, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Lift up on the small black tab at the connection point to unlock the flex ribbon cable using the tweezers.
  6. HP Stream 8 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the front facing camera with tweezers.
  7. HP Stream 8 Motherboard Replacement, Rear-Facing Camera: stap 7, afbeelding 1 van 1
    Koop
    • Carefully pry up the gray metal piece on the end of the flex ribbon cable using tweezers.
  8. HP Stream 8 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Remove the back facing camera with the tweezers.
  9. HP Stream 8 Motherboard Replacement, Motherboard: stap 9, afbeelding 1 van 1
    Koop
    • Carefully remove the battery connector from the system board using the tweezers.
  10. HP Stream 8 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Lift up on the small black tab to unlock the LCD screen flex ribbon cable using the tweezers.
  11. HP Stream 8 Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Carefully remove the LCD screen flex ribbon cable from the system board using the tweezers.
  12. HP Stream 8 Motherboard Replacement: stap 12, afbeelding 1 van 1
    • Carefully remove the USB flex ribbon cable from the connection point on the system board using the tweezers.
  13. HP Stream 8 Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Remove the two Phillips using the screwdriver with a PH00 Phillips head.
  14. HP Stream 8 Motherboard Replacement: stap 14, afbeelding 1 van 1
    • Remove the motherboard from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nick Miller
669 Reputatie
6 handleidingen geschreven
Cal Poly, Team 34-14, Maness Spring 2016 Lid van Cal Poly, Team 34-14, Maness Spring 2016
CPSU-MANESS-S16S34G14
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 14
Altijd: 1,079
