Inleiding
If the front facing camera on your HP Stream 8 is broken, use this guide to replace it. This guide requires a battery, unplug the device and power it off.
Wat je nodig hebt
Lift up on the small black tab at the connection point to unlock the flex ribbon cable using the tweezers.
Één andere persoon heeft deze handleiding voltooid.
