Ga door naar hoofdinhoud
HP Stream 13-c110nr Heat Sink Replacement
Wat je nodig hebt
  1. HP Stream 13-c110nr Heat Sink Replacement, Keyboard Assembly: stap 1, afbeelding 1 van 1
    • Close the device.
    • Remove AC adapter plug from electrical outlet.
    • Remove AC adapter from device.
    • Turn the device off.
    • Unplug all external devices from device.
    • If you are unsure whether the computer is off or in hibernation mode, start the computer and then shutdown the operating system.
  2. HP Stream 13-c110nr Heat Sink Replacement: stap 2, afbeelding 1 van 1
    • Turn the device upside down with the back facing towards you.
  3. HP Stream 13-c110nr Heat Sink Replacement: stap 3, afbeelding 1 van 3 HP Stream 13-c110nr Heat Sink Replacement: stap 3, afbeelding 2 van 3 HP Stream 13-c110nr Heat Sink Replacement: stap 3, afbeelding 3 van 3
    • Use a pick to remove the two (2) large computer feet along the back edge of the device.
    • Use a pick to remove the two (2) small computer feet.
    • Use a pick to remove the one (1) screw cover.
    • Place rubber computer feet in safe place for reassembly.
  4. HP Stream 13-c110nr Heat Sink Replacement: stap 4, afbeelding 1 van 3 HP Stream 13-c110nr Heat Sink Replacement: stap 4, afbeelding 2 van 3 HP Stream 13-c110nr Heat Sink Replacement: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    Koop
    • Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
    • Place the thirteen (13) screws on magnetic mat for reassembly.
  5. HP Stream 13-c110nr Heat Sink Replacement: stap 5, afbeelding 1 van 1
    • Turn the device over with the front facing towards you.
    • Open the device as shown.
  6. HP Stream 13-c110nr Heat Sink Replacement: stap 6, afbeelding 1 van 3 HP Stream 13-c110nr Heat Sink Replacement: stap 6, afbeelding 2 van 3 HP Stream 13-c110nr Heat Sink Replacement: stap 6, afbeelding 3 van 3
    • Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover.
    • Do not completely remove the Keyboard/Top cover from the Bottom cover yet.
  7. HP Stream 13-c110nr Heat Sink Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the Touchpad cable.
  8. HP Stream 13-c110nr Heat Sink Replacement: stap 8, afbeelding 1 van 2 HP Stream 13-c110nr Heat Sink Replacement: stap 8, afbeelding 2 van 2
    • Disconnect the Keyboard Cable.
  9. HP Stream 13-c110nr Heat Sink Replacement: stap 9, afbeelding 1 van 2 HP Stream 13-c110nr Heat Sink Replacement: stap 9, afbeelding 2 van 2
    • Disconnect the Power connector cable.
  10. HP Stream 13-c110nr Heat Sink Replacement: stap 10, afbeelding 1 van 1
    • Remove the Keyboard/Top Cover from the device.
  11. HP Stream 13-c110nr Heat Sink Replacement, Battery Assembly: stap 11, afbeelding 1 van 2 HP Stream 13-c110nr Heat Sink Replacement, Battery Assembly: stap 11, afbeelding 2 van 2
    • Use a pick to detach the Battery assembly cable.
  12. HP Stream 13-c110nr Heat Sink Replacement: stap 12, afbeelding 1 van 2 HP Stream 13-c110nr Heat Sink Replacement: stap 12, afbeelding 2 van 2
    • Remove eight (8) Phillips P0 PM2.0x3.0 mm screws from Battery assembly.
    • Place eight (8) screws on magnetic mat for reassembly.
  13. HP Stream 13-c110nr Heat Sink Replacement: stap 13, afbeelding 1 van 1
    • Remove Battery Assembly from device.
  14. HP Stream 13-c110nr Heat Sink Replacement, Heat Sink: stap 14, afbeelding 1 van 2 HP Stream 13-c110nr Heat Sink Replacement, Heat Sink: stap 14, afbeelding 2 van 2
    • Remove two (2) Phillips P0 PM2.0x2.0 mm screws.
    • Place two (2) screws on magnetic mat for reassembly.
  15. HP Stream 13-c110nr Heat Sink Replacement: stap 15, afbeelding 1 van 1
    • Remove the Heat Sink from the System Board.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 133
