Ga door naar hoofdinhoud
HP Stream 13-c010nr Display Replacement
Wat je nodig hebt
  1. HP Stream 13-c010nr Display Replacement, HP Stream 13-c010nr Disassembly: stap 1, afbeelding 1 van 1
    • Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
  2. HP Stream 13-c010nr Display Replacement: stap 2, afbeelding 1 van 2 HP Stream 13-c010nr Display Replacement: stap 2, afbeelding 2 van 2
    • Remove the thirteen 5mm Phillips #0 screws from the bottom case.
  3. HP Stream 13-c010nr Display Replacement: stap 3, afbeelding 1 van 2 HP Stream 13-c010nr Display Replacement: stap 3, afbeelding 2 van 2
    • Flip the laptop over and open it up.
    • Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
    • Lift up the keyboard.
    • Ribbon cables still connect the two pieces.
  4. HP Stream 13-c010nr Display Replacement: stap 4, afbeelding 1 van 1
    • Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
    • Pull up the ribbon cables from their sockets.
  5. HP Stream 13-c010nr Display Replacement, Display: stap 5, afbeelding 1 van 1
    • Remove the screw covers from the bottom corner edges of the screen.
  6. HP Stream 13-c010nr Display Replacement: stap 6, afbeelding 1 van 2 HP Stream 13-c010nr Display Replacement: stap 6, afbeelding 2 van 2
    • Remove the two 5mm Phillips #0 screws from the screen bezel.
  7. HP Stream 13-c010nr Display Replacement: stap 7, afbeelding 1 van 2 HP Stream 13-c010nr Display Replacement: stap 7, afbeelding 2 van 2
    • Wedge the plastic opening tool between the frame of the screen and the casing of the laptop.
    • Pry upwards on the plastic opening tool to separate the bezel from the display.
  8. HP Stream 13-c010nr Display Replacement: stap 8, afbeelding 1 van 1
    • Remove the four 3mm Phillips #0 screws from the screen.
  9. HP Stream 13-c010nr Display Replacement: stap 9, afbeelding 1 van 1
    • Use a spudger to flip up the retaining flap on the screen ribbon cable ZIF socket.
    • Pull the ribbon cable out of the ZIF socket.
    • Remove the screen.
Conclusie
Keegan Lapham
759 Reputatie
6 handleidingen geschreven
USF Tampa, Team S1-G3, Cagle Spring 2018 Lid van USF Tampa, Team S1-G3, Cagle Spring 2018
USFT-CAGLE-S18S1G3
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 14
Altijd: 734
