Ga door naar hoofdinhoud
HP Stream 11-y010nr Screen Replacement
Wat je nodig hebt
  1. HP Stream 11-y010nr Screen Replacement, Keyboard: stap 1, afbeelding 1 van 3 HP Stream 11-y010nr Screen Replacement, Keyboard: stap 1, afbeelding 2 van 3 HP Stream 11-y010nr Screen Replacement, Keyboard: stap 1, afbeelding 3 van 3
    • Gently peel back the two rubber strips that cover the screws on backside of the computer with the needle nose tweezers.
    • Ensure the laptop is turned off.
  2. HP Stream 11-y010nr Screen Replacement: stap 2, afbeelding 1 van 2 HP Stream 11-y010nr Screen Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the seven 0.4mm screws on the backside of the laptop with the Phillips #0 Screwdriver.
  3. HP Stream 11-y010nr Screen Replacement: stap 3, afbeelding 1 van 2 HP Stream 11-y010nr Screen Replacement: stap 3, afbeelding 2 van 2
    • Take the opening picks and push them into the seam between the keyboard and the laptop casing.
    • Go all the way around the laptop.
  4. HP Stream 11-y010nr Screen Replacement: stap 4, afbeelding 1 van 1
    • Once the cover is loose enough, lift the keyboard up to expose the wiring beneath.
    • Be careful not to pull too hard or fast as there are ribbon cables attached to the keyboard and trackpad.
  5. HP Stream 11-y010nr Screen Replacement: stap 5, afbeelding 1 van 3 HP Stream 11-y010nr Screen Replacement: stap 5, afbeelding 2 van 3 HP Stream 11-y010nr Screen Replacement: stap 5, afbeelding 3 van 3
    • Disconnect the three cables by lifting up on the locking tab of the ZIF connector and pulling the cables out with the needle nose tweezers.
    • Remove the keyboard.
  6. HP Stream 11-y010nr Screen Replacement, Screen: stap 6, afbeelding 1 van 3 HP Stream 11-y010nr Screen Replacement, Screen: stap 6, afbeelding 2 van 3 HP Stream 11-y010nr Screen Replacement, Screen: stap 6, afbeelding 3 van 3
    • Using your fingers or a spudger, pull the battery cable from its connector to disconnect power from the motherboard.
  7. HP Stream 11-y010nr Screen Replacement: stap 7, afbeelding 1 van 2 HP Stream 11-y010nr Screen Replacement: stap 7, afbeelding 2 van 2
    • Insert iFixit opening picks into the edges of the screen to break the seal between the screen and bezel.
  8. HP Stream 11-y010nr Screen Replacement: stap 8, afbeelding 1 van 3 HP Stream 11-y010nr Screen Replacement: stap 8, afbeelding 2 van 3 HP Stream 11-y010nr Screen Replacement: stap 8, afbeelding 3 van 3
    • Peel the hinge up by sliding iFixit opening picks left to right along the hinge.
  9. HP Stream 11-y010nr Screen Replacement: stap 9, afbeelding 1 van 3 HP Stream 11-y010nr Screen Replacement: stap 9, afbeelding 2 van 3 HP Stream 11-y010nr Screen Replacement: stap 9, afbeelding 3 van 3
    • Remove the bezel by pulling upwards on the left bottom corner.
  10. HP Stream 11-y010nr Screen Replacement: stap 10, afbeelding 1 van 2 HP Stream 11-y010nr Screen Replacement: stap 10, afbeelding 2 van 2
    • Disconnect the screen from the motherboard by pulling the display cable from its connector.
  11. HP Stream 11-y010nr Screen Replacement: stap 11, afbeelding 1 van 1
    • Unscrew the four 0.4mm screws surrounding the display using a Phillips #00 screwdriver.
  12. HP Stream 11-y010nr Screen Replacement: stap 12, afbeelding 1 van 3 HP Stream 11-y010nr Screen Replacement: stap 12, afbeelding 2 van 3 HP Stream 11-y010nr Screen Replacement: stap 12, afbeelding 3 van 3
    • Gently remove the screen from its holding and lay the screen down on the keyboard. It is still attached to the computer.
  13. HP Stream 11-y010nr Screen Replacement: stap 13, afbeelding 1 van 3 HP Stream 11-y010nr Screen Replacement: stap 13, afbeelding 2 van 3 HP Stream 11-y010nr Screen Replacement: stap 13, afbeelding 3 van 3
    • Take the tweezers and push up on the small connector to the left of the webcam.
  14. HP Stream 11-y010nr Screen Replacement: stap 14, afbeelding 1 van 2 HP Stream 11-y010nr Screen Replacement: stap 14, afbeelding 2 van 2
    • Gently pull the cord out from around the screen area.
  15. HP Stream 11-y010nr Screen Replacement: stap 15, afbeelding 1 van 2 HP Stream 11-y010nr Screen Replacement: stap 15, afbeelding 2 van 2
    • Remove the screen with the display cable attached.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 464
