Ga door naar hoofdinhoud
HP Stream 11-y010nr Keyboard Replacement
Wat je nodig hebt
  1. HP Stream 11-y010nr Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 3 HP Stream 11-y010nr Keyboard Replacement, Keyboard: stap 1, afbeelding 2 van 3 HP Stream 11-y010nr Keyboard Replacement, Keyboard: stap 1, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Gently peel back the two rubber strips that cover the screws on backside of the computer with the needle nose tweezers.
    • Ensure the laptop is turned off.
  2. HP Stream 11-y010nr Keyboard Replacement: stap 2, afbeelding 1 van 2 HP Stream 11-y010nr Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the seven 0.4mm screws on the backside of the laptop with the Phillips #0 Screwdriver.
  3. HP Stream 11-y010nr Keyboard Replacement: stap 3, afbeelding 1 van 2 HP Stream 11-y010nr Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Take the opening picks and push them into the seam between the keyboard and the laptop casing.
    • Go all the way around the laptop.
  4. HP Stream 11-y010nr Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Once the cover is loose enough, lift the keyboard up to expose the wiring beneath.
    • Be careful not to pull too hard or fast as there are ribbon cables attached to the keyboard and trackpad.
  5. HP Stream 11-y010nr Keyboard Replacement: stap 5, afbeelding 1 van 3 HP Stream 11-y010nr Keyboard Replacement: stap 5, afbeelding 2 van 3 HP Stream 11-y010nr Keyboard Replacement: stap 5, afbeelding 3 van 3
    • Disconnect the three cables by lifting up on the locking tab of the ZIF connector and pulling the cables out with the needle nose tweezers.
    • Remove the keyboard.
Conclusie
To reassemble your device, follow these instructions.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 584
