Inleiding
This guide will walk you through the process of replacing a faulty or damaged screen in an HP Stream 11 laptop. This should take you about 10-15 minutes. There are hidden screws under plastic covers that inhibit your ability to remove the screen and could damage your screen. Once these screws are removed it is fairly simple to remove your screen.
Wat je nodig hebt
Pry off the two elliptical rubber inserts (one in each corner).
Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
Tilt the top of the keyboard plate up until you separate it from the base.
Tilt the keyboard toward you slowly but do not remove it, it is still connected with ribbon cables.
Lift the black flap on the display cable ZIF connector.
After lifting the flap, gently pull the display cable from its socket.
Disconnect the wireless antenna from the wireless card.
Remove the four 2.2 mm Phillips #00 screws on the left and right sides of the laptop.
Unscrew the four 3.3mm Phillips #000 screws as indicated.
Lift the screen from the lid carefully.
11 andere personen hebben deze handleiding voltooid.
