Inleiding
Sometimes your keys may get sticky and impair your use of the laptop. So you may need to replace the keyboard. However, you should be careful when removing any parts from the laptop, as many parts are attached to other parts by wires. Applying too much force when removing components may damage these wires. Also, many of the connections are just melted plastic which means it may sound like you're breaking the device, but it's necessary to get the device open. Always use caution to avoid unnecessary damages as well.
Wat je nodig hebt
Pry off the two elliptical rubber inserts (one in each corner).
Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
Tilt the top of the keyboard plate up until you separate it from the base.
Tilt the keyboard toward you slowly but do not remove it, it is still connected with ribbon cables.
6 andere personen hebben deze handleiding voltooid.
Één opmerking
This repair is disingenuous and misleading. The computer used in these photos was previously worked on. All of the pictures and instructions in Step 4 and Step 5 prove this. In those pictures the keyboard is a physically separate piece from the plastic top case. This is NOT how this computer is assembled. In fact the keyboard is plastic welded to the top case. The top case does not separate from the keyboard as seen in Step 4 and Step 5. You need to fully remove the top case (which contains the keyboard and trackpad), disconnect three cables, remove a large copper support and a small black plastic support, peel off a big sheet of plastic and graphite insulation tape, then cut about 25 plastic welds that hold the keyboard support to the top case. Only then you can separate the keyboard from the top case.
