Ga door naar hoofdinhoud
HP Stream 11-d008TU Heatsink Replacement
Wat je nodig hebt
  1. HP Stream 11-d008TU Heatsink Replacement, Rubber Feet Removal: stap 1, afbeelding 1 van 3 HP Stream 11-d008TU Heatsink Replacement, Rubber Feet Removal: stap 1, afbeelding 2 van 3 HP Stream 11-d008TU Heatsink Replacement, Rubber Feet Removal: stap 1, afbeelding 3 van 3
    • Use a prying tool to pry the 2 rubber feet off closest to the hinge of the device
    • Repeat this process for the other side of the device
    • The bottom rubber feet do not have hidden screws underneath them, and as such, they are unnecessary to remove
  2. HP Stream 11-d008TU Heatsink Replacement, Screw removal: stap 2, afbeelding 1 van 2 HP Stream 11-d008TU Heatsink Replacement, Screw removal: stap 2, afbeelding 2 van 2
    • Remove the 11x 5mm Phillips PH-0 screws (circled)
  3. HP Stream 11-d008TU Heatsink Replacement, Keyboard Unclipping: stap 3, afbeelding 1 van 3 HP Stream 11-d008TU Heatsink Replacement, Keyboard Unclipping: stap 3, afbeelding 2 van 3 HP Stream 11-d008TU Heatsink Replacement, Keyboard Unclipping: stap 3, afbeelding 3 van 3
    • Use your finger to pry the outer blue shell over the keyboard
    • Continue this process around the edges of the device
    • You may have to use a prying tool to pry the harder edges such as around the I/O ports
    • Do not lift the keyboard once all the clips are undone, as there are still various cables connected
  4. HP Stream 11-d008TU Heatsink Replacement, Keyboard removal: stap 4, afbeelding 1 van 3 HP Stream 11-d008TU Heatsink Replacement, Keyboard removal: stap 4, afbeelding 2 van 3 HP Stream 11-d008TU Heatsink Replacement, Keyboard removal: stap 4, afbeelding 3 van 3
    • Disconnect the power button connector by peeling back the protective tape, using your fingernail to flip the white retaining clip back, and pulling the ribbon cable out
    • Disconnect the touchpad connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Disconnect the keyboard connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Your keyboard assembly is now safe to remove
  5. HP Stream 11-d008TU Heatsink Replacement, Unscrew the heatsink: stap 5, afbeelding 1 van 1
    • Unscrew the four 2.5mm M2x2.5 PH-0 Phillips head screws in reverse numerical order (4-3-2-1)
    • 4: Bottom left | 3: Top Right | 2: Bottom Right | 1: Top Left
  6. HP Stream 11-d008TU Heatsink Replacement, Remove the heatsink: stap 6, afbeelding 1 van 2 HP Stream 11-d008TU Heatsink Replacement, Remove the heatsink: stap 6, afbeelding 2 van 2
    • Lift the heatsink
Conclusie
Één andere persoon heeft deze handleiding voltooid.
CONVERSION
1.282 Reputatie
8 handleidingen geschreven
Australia Lid van Australia
Community
4 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 85
