Inleiding
The USB port on the HP Sprocket 2-in-1 is a micro-USB port. The removal of said port will involve navigating and detaching numerous small and delicate ribbon cables. Be sure to avoid aggressive movements while completing the guide to avoid taring connections to other vital components.
Wat je nodig hebt
Use a JIS #00 screwdriver to remove a single black screw near the viewfinder.
Remove a single silver 2.5mm JIS #00 screw near the USB port of the device.
Carefully remove the metal bracket.
Using the metal tweezers, remove the ribbon from the motherboard.
Remove two 2.5mm Japanese Industrial Standard (J00) screws on each side of the USB port.
Één andere persoon heeft deze handleiding voltooid.
