Ga door naar hoofdinhoud
HP Sprocket 2-in-1 Outer Casing Replacement
Wat je nodig hebt
  1. HP Sprocket 2-in-1 Outer Casing Replacement, Outer Casing: stap 1, afbeelding 1 van 2 HP Sprocket 2-in-1 Outer Casing Replacement, Outer Casing: stap 1, afbeelding 2 van 2
    • Remove the back cover and any printer paper inside the device.
  2. HP Sprocket 2-in-1 Outer Casing Replacement: stap 2, afbeelding 1 van 2 HP Sprocket 2-in-1 Outer Casing Replacement: stap 2, afbeelding 2 van 2
    • Using the Jimmy, slowly pry open the outer edge of the remaining white plastic on the back.
    • Remove the plastic from the device once it lifts out freely.
  3. HP Sprocket 2-in-1 Outer Casing Replacement: stap 3, afbeelding 1 van 3 HP Sprocket 2-in-1 Outer Casing Replacement: stap 3, afbeelding 2 van 3 HP Sprocket 2-in-1 Outer Casing Replacement: stap 3, afbeelding 3 van 3
    • Remove two 2.5mm JIS #00 located on the small circuit board in view.
    • Use the Jimmy to remove the board after the screws have been removed.
    • Be careful not to crease or damage the ribbon cable.
  4. HP Sprocket 2-in-1 Outer Casing Replacement: stap 4, afbeelding 1 van 3 HP Sprocket 2-in-1 Outer Casing Replacement: stap 4, afbeelding 2 van 3 HP Sprocket 2-in-1 Outer Casing Replacement: stap 4, afbeelding 3 van 3
    • Remove two 2.5mm JIS #00 screws from the translucent plastic bracket.
    • One will be located beneath the ribbon cable.
    • Remove the translucent plastic bracket by hand.
  5. HP Sprocket 2-in-1 Outer Casing Replacement: stap 5, afbeelding 1 van 2 HP Sprocket 2-in-1 Outer Casing Replacement: stap 5, afbeelding 2 van 2
    • Remove four 2.5mm JIS #00 screws from the beige casing.
  6. HP Sprocket 2-in-1 Outer Casing Replacement: stap 6, afbeelding 1 van 3 HP Sprocket 2-in-1 Outer Casing Replacement: stap 6, afbeelding 2 van 3 HP Sprocket 2-in-1 Outer Casing Replacement: stap 6, afbeelding 3 van 3
    • Use the iFixit opening tool to slowly work between the white and beige casing around the device.
    • Flip the device over and seperate the white casing from the rest of the device.
    • Be careful not to break the plastic while removing the case.
    • Gently remove the white casing as there is a ribbon cable connecting the two pieces.
  7. HP Sprocket 2-in-1 Outer Casing Replacement: stap 7, afbeelding 1 van 1
    • Carefully remove the ribbon cable that connects the flash to the outer casing.
Conclusie
Kevin Steward
178 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 335
