Ga door naar hoofdinhoud
HP Split x2 13-g210dx Speakers Replacement
Wat je nodig hebt
  1. HP Split x2 13-g210dx Speakers Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
    • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
    • Remove the four 4-mm Phillips #0 screws.
    • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
    • You will hear popping noises as the clips separate from each other.
  2. HP Split x2 13-g210dx Speakers Replacement, Battery: stap 2, afbeelding 1 van 1
    • Remove the three 6-mm Phillips #0 screws.
  3. HP Split x2 13-g210dx Speakers Replacement: stap 3, afbeelding 1 van 2 HP Split x2 13-g210dx Speakers Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the white connector clip from the connector port using a sturdy tweezers.
  4. HP Split x2 13-g210dx Speakers Replacement: stap 4, afbeelding 1 van 2 HP Split x2 13-g210dx Speakers Replacement: stap 4, afbeelding 2 van 2
    • Lift the battery away from the device.
  5. HP Split x2 13-g210dx Speakers Replacement, Docking Port: stap 5, afbeelding 1 van 1
    • Remove the two 4-mm Phillips #0 screws.
  6. HP Split x2 13-g210dx Speakers Replacement: stap 6, afbeelding 1 van 2 HP Split x2 13-g210dx Speakers Replacement: stap 6, afbeelding 2 van 2
    Koop
    • Remove the clips from the docking port board with a sturdy pair of tweezers.
  7. HP Split x2 13-g210dx Speakers Replacement: stap 7, afbeelding 1 van 2 HP Split x2 13-g210dx Speakers Replacement: stap 7, afbeelding 2 van 2
    • Remove the two ribbons labeled "Dock" at the top of the docking port board using tweezers or a sturdy plastic opening tool.
  8. HP Split x2 13-g210dx Speakers Replacement: stap 8, afbeelding 1 van 1
    • Lift the docking port away from the device.
  9. HP Split x2 13-g210dx Speakers Replacement, SD Port: stap 9, afbeelding 1 van 1
  10. HP Split x2 13-g210dx Speakers Replacement: stap 10, afbeelding 1 van 2 HP Split x2 13-g210dx Speakers Replacement: stap 10, afbeelding 2 van 2
    Koop
    • Remove the yellow ribbon labeled "SD" in the left corner of the SD port board using tweezers or a sturdy plastic opening tool.
  11. HP Split x2 13-g210dx Speakers Replacement: stap 11, afbeelding 1 van 1
    • Lift the SD port away from the device.
  12. HP Split x2 13-g210dx Speakers Replacement, Audio Port: stap 12, afbeelding 1 van 1
  13. HP Split x2 13-g210dx Speakers Replacement: stap 13, afbeelding 1 van 3 HP Split x2 13-g210dx Speakers Replacement: stap 13, afbeelding 2 van 3 HP Split x2 13-g210dx Speakers Replacement: stap 13, afbeelding 3 van 3
    Koop
    • Remove the two purple ribbons labeled "Audio" at the top of the audio port board using tweezers or a sturdy plastic opening tool.
  14. HP Split x2 13-g210dx Speakers Replacement: stap 14, afbeelding 1 van 2 HP Split x2 13-g210dx Speakers Replacement: stap 14, afbeelding 2 van 2
    • Remove the white clip at the top right corner of the audio port board using tweezers.
  15. HP Split x2 13-g210dx Speakers Replacement: stap 15, afbeelding 1 van 1
    • Lift the Audio port away from the device.
  16. HP Split x2 13-g210dx Speakers Replacement, Speakers: stap 16, afbeelding 1 van 2 HP Split x2 13-g210dx Speakers Replacement, Speakers: stap 16, afbeelding 2 van 2
    • Remove the 4-mm Phillips #0 screw.
    • Lift the left speaker away from the device.
  17. HP Split x2 13-g210dx Speakers Replacement: stap 17, afbeelding 1 van 2 HP Split x2 13-g210dx Speakers Replacement: stap 17, afbeelding 2 van 2
    • Remove the 4-mm Phillips #0 screw from the same location as found on the left speaker.
    • Lift the right speaker away from the device.
  18. HP Split x2 13-g210dx Speakers Replacement: stap 18, afbeelding 1 van 3 HP Split x2 13-g210dx Speakers Replacement: stap 18, afbeelding 2 van 3 HP Split x2 13-g210dx Speakers Replacement: stap 18, afbeelding 3 van 3
    • Carefully remove the bonded white and black speaker wires running along the bottom of the control board from the fastening clips.
    • Lift the speaker assembly away from the device.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 9
Altijd: 269
