Ga door naar hoofdinhoud
HP Split x2 13-g210dx Battery Replacement
Wat je nodig hebt
  1. HP Split x2 13-g210dx Battery Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
    • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
    • Remove the four 4-mm Phillips #0 screws.
    • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
    • You will hear popping noises as the clips separate from each other.
  2. HP Split x2 13-g210dx Battery Replacement, Battery: stap 2, afbeelding 1 van 1
    • Remove the three 6-mm Phillips #0 screws.
  3. HP Split x2 13-g210dx Battery Replacement: stap 3, afbeelding 1 van 2 HP Split x2 13-g210dx Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the white connector clip from the connector port using a sturdy tweezers.
  4. HP Split x2 13-g210dx Battery Replacement: stap 4, afbeelding 1 van 2 HP Split x2 13-g210dx Battery Replacement: stap 4, afbeelding 2 van 2
    • Lift the battery away from the device.
Conclusie
4 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 2,006
