Ga door naar hoofdinhoud
HP Split x2 13-g210dx Back Panel Replacement
Wat je nodig hebt
  1. HP Split x2 13-g210dx Back Panel Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
    • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
    • Remove the four 4-mm Phillips #0 screws.
    • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
    • You will hear popping noises as the clips separate from each other.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
How do I put the felt cover back on?
Prince Phoenix - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 7
Altijd: 379
