Ga door naar hoofdinhoud
HP Split 13-r010dx Screen Replacement
Wat je nodig hebt
  1. HP Split 13-r010dx Screen Replacement, Front and Back Panel: stap 1, afbeelding 1 van 2 HP Split 13-r010dx Screen Replacement, Front and Back Panel: stap 1, afbeelding 2 van 2
    • Locate the four screws at the bottom of the device. (Note that the keyboard attachment is missing from this device.)
    • Use a Philips head #0 screwdriver to remove each of the screws (Size: 4mm)
  2. HP Split 13-r010dx Screen Replacement: stap 2, afbeelding 1 van 2 HP Split 13-r010dx Screen Replacement: stap 2, afbeelding 2 van 2
    • Gently wedge the plastic opening tool in between where the display and back panel meet.
    • Slowly and gently apply force to the plastic opening tool in a downwards motion to loosen the front panel from the back panel.
    • Rotate the device so that the side is facing up and repeat the previous step for the sides.
    • Do NOT attempt to wedge the plastic opening tool on the bottom . Once the sides and top are loose you are ready to continue to the next step.
  3. HP Split 13-r010dx Screen Replacement: stap 3, afbeelding 1 van 1
    • Gently and slowly pull the front and back panel away from each other (in opposite directions). ( Pulling them apart will not separate the two panels)
    • Only separate the panels by a few inches from each other so that there is room to separate the front and back panel in the next step. Proceed to the next step.
  4. HP Split 13-r010dx Screen Replacement: stap 4, afbeelding 1 van 1
    • Hold the back panel firmly and pull the front panel upwards to completely separate the front panel from the back panel.
    • The device is now ready to be repaired or replacements installed.
  5. HP Split 13-r010dx Screen Replacement, Screen: stap 5, afbeelding 1 van 3 HP Split 13-r010dx Screen Replacement, Screen: stap 5, afbeelding 2 van 3 HP Split 13-r010dx Screen Replacement, Screen: stap 5, afbeelding 3 van 3
    • Use the PH1 screwdriver to remove eleven 4mm Phillips screws.
  6. HP Split 13-r010dx Screen Replacement: stap 6, afbeelding 1 van 2 HP Split 13-r010dx Screen Replacement: stap 6, afbeelding 2 van 2
    • Unscrew the two 2mm zero insertion force connectors. Slide aside the white wires to properly unscrew.
  7. HP Split 13-r010dx Screen Replacement: stap 7, afbeelding 1 van 3 HP Split 13-r010dx Screen Replacement: stap 7, afbeelding 2 van 3 HP Split 13-r010dx Screen Replacement: stap 7, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Use a pair of tweezers to pull up the yellow colored display cable connector.
    • Pull it to the direction of the cable.
  8. HP Split 13-r010dx Screen Replacement: stap 8, afbeelding 1 van 1
    • Glue is attached at the edges. Apply force to the sides of the tablet. Separate the digitizer from the body of the tablet.
    • Replace the old screen with a new one.
    • If your screen is broken or damaged, use caution when pulling the screen from the tablet to avoid self harm.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
bushraishaq
327 Reputatie
2 handleidingen geschreven
Één opmerking
Hello… How to know if it is the digitizer or the screen that is broken? .. thanks
Martin Sala - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 644
