Ga door naar hoofdinhoud
HP Spectre x360 13t-4000 Speakers Replacement
Wat je nodig hebt
  1. HP Spectre x360 13t-4000 Speakers Replacement, Bottom Cover: stap 1, afbeelding 1 van 2 HP Spectre x360 13t-4000 Speakers Replacement, Bottom Cover: stap 1, afbeelding 2 van 2
    • Turn off and unplug the laptop.
    • Flip over the laptop so that the bottom backplate is exposed.
  2. HP Spectre x360 13t-4000 Speakers Replacement: stap 2, afbeelding 1 van 2 HP Spectre x360 13t-4000 Speakers Replacement: stap 2, afbeelding 2 van 2
    • Use a T5 screwdriver to remove the six 3 mm screws that secure the backplate.
    • Use the same screwdriver to remove the two 7 mm screws.
  3. HP Spectre x360 13t-4000 Speakers Replacement: stap 3, afbeelding 1 van 3 HP Spectre x360 13t-4000 Speakers Replacement: stap 3, afbeelding 2 van 3 HP Spectre x360 13t-4000 Speakers Replacement: stap 3, afbeelding 3 van 3
    • Insert an opening tool under the bottom cover at the screen hinges, and gently pry the cover free.
    • Carefully work your way around the cover's edges to pop it off completely.
  4. HP Spectre x360 13t-4000 Speakers Replacement, Battery: stap 4, afbeelding 1 van 3 HP Spectre x360 13t-4000 Speakers Replacement, Battery: stap 4, afbeelding 2 van 3 HP Spectre x360 13t-4000 Speakers Replacement, Battery: stap 4, afbeelding 3 van 3
    • With the backplate removed, remove the four 3 mm screws securing the battery with a Phillips #1 screwdriver.
    • With the screws removed, disconnect the 3 wires connected to the battery.
    • Tweezers may be needed to remove the wires.
  5. HP Spectre x360 13t-4000 Speakers Replacement, Speakers: stap 5, afbeelding 1 van 3 HP Spectre x360 13t-4000 Speakers Replacement, Speakers: stap 5, afbeelding 2 van 3 HP Spectre x360 13t-4000 Speakers Replacement, Speakers: stap 5, afbeelding 3 van 3
    • With the backplate and battery removed from the device, remove the three 2mm screws using the Phillips #0 screwdriver.
  6. HP Spectre x360 13t-4000 Speakers Replacement: stap 6, afbeelding 1 van 2 HP Spectre x360 13t-4000 Speakers Replacement: stap 6, afbeelding 2 van 2
    • With all three screws removed, remove the speaker assembly from the device.
Conclusie
Michael Bisbano
88 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team S2-G4, Simcock Spring 2019 Lid van UMass Dartmouth, Team S2-G4, Simcock Spring 2019
UMASSD-SIMCOCK-S19S2G4
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 12
Altijd: 1,289
