Ga door naar hoofdinhoud
HP Spectre x360 13t-4000 Motherboard Replacement
Wat je nodig hebt
  1. HP Spectre x360 13t-4000 Motherboard Replacement, Bottom Cover: stap 1, afbeelding 1 van 2 HP Spectre x360 13t-4000 Motherboard Replacement, Bottom Cover: stap 1, afbeelding 2 van 2
    • Turn off and unplug the laptop.
    • Flip over the laptop so that the bottom backplate is exposed.
  2. HP Spectre x360 13t-4000 Motherboard Replacement: stap 2, afbeelding 1 van 2 HP Spectre x360 13t-4000 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Use a T5 screwdriver to remove the six 3 mm screws that secure the backplate.
    • Use the same screwdriver to remove the two 7 mm screws.
  3. HP Spectre x360 13t-4000 Motherboard Replacement: stap 3, afbeelding 1 van 3 HP Spectre x360 13t-4000 Motherboard Replacement: stap 3, afbeelding 2 van 3 HP Spectre x360 13t-4000 Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Insert an opening tool under the bottom cover at the screen hinges, and gently pry the cover free.
    • Carefully work your way around the cover's edges to pop it off completely.
  4. HP Spectre x360 13t-4000 Motherboard Replacement, Battery: stap 4, afbeelding 1 van 3 HP Spectre x360 13t-4000 Motherboard Replacement, Battery: stap 4, afbeelding 2 van 3 HP Spectre x360 13t-4000 Motherboard Replacement, Battery: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • With the backplate removed, remove the four 3 mm screws securing the battery with a Phillips #1 screwdriver.
    • With the screws removed, disconnect the 3 wires connected to the battery.
    • Tweezers may be needed to remove the wires.
  5. HP Spectre x360 13t-4000 Motherboard Replacement, Heatsink and Fan Assembly: stap 5, afbeelding 1 van 3 HP Spectre x360 13t-4000 Motherboard Replacement, Heatsink and Fan Assembly: stap 5, afbeelding 2 van 3 HP Spectre x360 13t-4000 Motherboard Replacement, Heatsink and Fan Assembly: stap 5, afbeelding 3 van 3
    • Use a Phillips #0 Screwdriver to remove the four circled 3 mm screws.
    • Use the same screwdriver to remove the circled 4 mm screw.
  6. HP Spectre x360 13t-4000 Motherboard Replacement: stap 6, afbeelding 1 van 2 HP Spectre x360 13t-4000 Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Remove black adhesive tape and metal shielding.
  7. HP Spectre x360 13t-4000 Motherboard Replacement: stap 7, afbeelding 1 van 2 HP Spectre x360 13t-4000 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the last 4 mm screw under the black tape.
    • Unplug the cable next to the fan.
  8. HP Spectre x360 13t-4000 Motherboard Replacement: stap 8, afbeelding 1 van 2 HP Spectre x360 13t-4000 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Remove heatsink and fan assembly.
    • Reapply fresh thermal paste to the CPU before placing a heatsink back in the device.
  9. HP Spectre x360 13t-4000 Motherboard Replacement, Motherboard: stap 9, afbeelding 1 van 1
    • Use a Phillips #0 Screwdriver to remove the 2.6 mm and 2.7 mm screws.
    • Strip wire present in the motherboard must also be removed
  10. HP Spectre x360 13t-4000 Motherboard Replacement: stap 10, afbeelding 1 van 3 HP Spectre x360 13t-4000 Motherboard Replacement: stap 10, afbeelding 2 van 3 HP Spectre x360 13t-4000 Motherboard Replacement: stap 10, afbeelding 3 van 3
    • For the strip wires, push the white tab seen in the photo up gently and slowly pull the strip wire.
    • The normal wires can be removed by holding the sides of the connector and gently pulling away.
    • Finally, the screws can be removed.
  11. HP Spectre x360 13t-4000 Motherboard Replacement: stap 11, afbeelding 1 van 1
    • You may now pull the motherboard off the computer to access it.
Conclusie
Justin Dages
361 Reputatie
3 handleidingen geschreven
IUPUI, Team 2-5, Harley Spring 2023 Lid van IUPUI, Team 2-5, Harley Spring 2023
IUPUI-HARLEY-S23S2G5
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 187
