Ga door naar hoofdinhoud
HP Spectre x360 13t-4000 Bottom Cover Replacement
Wat je nodig hebt
  1. HP Spectre x360 13t-4000 Bottom Cover Replacement, Bottom Cover: stap 1, afbeelding 1 van 2 HP Spectre x360 13t-4000 Bottom Cover Replacement, Bottom Cover: stap 1, afbeelding 2 van 2
    • Turn off and unplug the laptop.
    • Flip over the laptop so that the bottom backplate is exposed.
  2. HP Spectre x360 13t-4000 Bottom Cover Replacement: stap 2, afbeelding 1 van 2 HP Spectre x360 13t-4000 Bottom Cover Replacement: stap 2, afbeelding 2 van 2
    • Use a T5 screwdriver to remove the six 3 mm screws that secure the backplate.
    • Use the same screwdriver to remove the two 7 mm screws.
  3. HP Spectre x360 13t-4000 Bottom Cover Replacement: stap 3, afbeelding 1 van 3 HP Spectre x360 13t-4000 Bottom Cover Replacement: stap 3, afbeelding 2 van 3 HP Spectre x360 13t-4000 Bottom Cover Replacement: stap 3, afbeelding 3 van 3
    • Insert an opening tool under the bottom cover at the screen hinges, and gently pry the cover free.
    • Carefully work your way around the cover's edges to pop it off completely.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Brandon Carvalho
566 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S2-G4, Simcock Spring 2019 Lid van UMass Dartmouth, Team S2-G4, Simcock Spring 2019
UMASSD-SIMCOCK-S19S2G4
3 Leden
6 handleidingen geschreven
Één opmerking
Any idea for previous model like acxxxx? The 5mm screw aren't visible, bit it's like if they are there. The corners won't come out. Is the screws hidden deep under the rubber pad? Removed the rubber, do we need to somehow remove the plastic part on which the rubber pad are glued? If so how? They seems to be glued on
Ben - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 1,102
