Ga door naar hoofdinhoud
HP Spectre x360 13-aw0xxx Battery Replacement
Wat je nodig hebt
  1. HP Spectre x360 13-aw0xxx Battery Replacement, Lower Case: stap 1, afbeelding 1 van 2 HP Spectre x360 13-aw0xxx Battery Replacement, Lower Case: stap 1, afbeelding 2 van 2
    • Remove the following screws securing the lower case:
    • Four Phillips #00 6 mm screws
    • Two T5 Torx 3 mm screws
  2. HP Spectre x360 13-aw0xxx Battery Replacement: stap 2, afbeelding 1 van 1
    • Insert an opening tool in the seam between the lower case and chassis.
    • Pry around the perimeter until the lower case fully releases.
    • Remove the lower case.
  3. HP Spectre x360 13-aw0xxx Battery Replacement, Battery: stap 3, afbeelding 1 van 2 HP Spectre x360 13-aw0xxx Battery Replacement, Battery: stap 3, afbeelding 2 van 2
    • Use two opening tools, one on either side of the battery plug, to slowly pull the plug straight out of its port.
    • Alternatively, use your fingernails.
  4. HP Spectre x360 13-aw0xxx Battery Replacement: stap 4, afbeelding 1 van 2 HP Spectre x360 13-aw0xxx Battery Replacement: stap 4, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the six 2.5 mm screws securing the battery.
  5. HP Spectre x360 13-aw0xxx Battery Replacement: stap 5, afbeelding 1 van 2 HP Spectre x360 13-aw0xxx Battery Replacement: stap 5, afbeelding 2 van 2
    • Carefully lift the edge of the battery with an opening tool.
    • Lift the battery up and out.
Conclusie
Thomas Hayslett
97 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 40
Afgelopen 30 dagen: 141
Altijd: 1,347
