Ga door naar hoofdinhoud
HP Spectre x360 13-ac023dx Motherboard Replacement
Wat je nodig hebt
  1. HP Spectre x360 13-ac023dx Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 HP Spectre x360 13-ac023dx Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the laptop over so the model sticker faces the ceiling.
  2. HP Spectre x360 13-ac023dx Motherboard Replacement: stap 2, afbeelding 1 van 3 HP Spectre x360 13-ac023dx Motherboard Replacement: stap 2, afbeelding 2 van 3 HP Spectre x360 13-ac023dx Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
  3. HP Spectre x360 13-ac023dx Motherboard Replacement: stap 3, afbeelding 1 van 2 HP Spectre x360 13-ac023dx Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
    • After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
    • Then, carefully lift the battery off with the iFixit opening tool.
  4. HP Spectre x360 13-ac023dx Motherboard Replacement, Fan: stap 4, afbeelding 1 van 1
    • Locate the Cooling Fan in the device.
  5. HP Spectre x360 13-ac023dx Motherboard Replacement: stap 5, afbeelding 1 van 2 HP Spectre x360 13-ac023dx Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Use the Phillips #000 screwdriver to remove the 3mm screws holding the fan in place.
    • Remove the wires connecting to the motherboard, using the iFixit opening tool.
    • The iFixit Opening Tool is not required, but recommended
  6. HP Spectre x360 13-ac023dx Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the Cooling Fan.
  7. HP Spectre x360 13-ac023dx Motherboard Replacement, WiFi Card: stap 7, afbeelding 1 van 1
    • Locate the WiFi card.
  8. HP Spectre x360 13-ac023dx Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Use the Phillips #000 screwdriver to remove the screw holding the wifi card in place.
  9. HP Spectre x360 13-ac023dx Motherboard Replacement: stap 9, afbeelding 1 van 2 HP Spectre x360 13-ac023dx Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Once the screw is removed, raise the WiFi card and slide it out from the motherboard.
  10. HP Spectre x360 13-ac023dx Motherboard Replacement, Motherboard: stap 10, afbeelding 1 van 1
    • Ensure that all other components which were previously removed are not longer attached.
  11. HP Spectre x360 13-ac023dx Motherboard Replacement: stap 11, afbeelding 1 van 3 HP Spectre x360 13-ac023dx Motherboard Replacement: stap 11, afbeelding 2 van 3 HP Spectre x360 13-ac023dx Motherboard Replacement: stap 11, afbeelding 3 van 3
    • Disconnect the wires which connect the motherboard to the rest of the components.
    • The black and red wire can be removed by pulling the wire upwards.
  12. HP Spectre x360 13-ac023dx Motherboard Replacement: stap 12, afbeelding 1 van 3 HP Spectre x360 13-ac023dx Motherboard Replacement: stap 12, afbeelding 2 van 3 HP Spectre x360 13-ac023dx Motherboard Replacement: stap 12, afbeelding 3 van 3
    • Use the Phillips #000 screwdriver to remove the three 3.5 mm screws which keep the motherboard in place.
  13. HP Spectre x360 13-ac023dx Motherboard Replacement: stap 13, afbeelding 1 van 2 HP Spectre x360 13-ac023dx Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Carefully lift and remove the motherboard.
Conclusie
Jonathan
486 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S1-G6, Botvin Fall 2019 Lid van UMass Dartmouth, Team S1-G6, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G6
3 Leden
6 handleidingen geschreven
Één opmerking
Can I get ho spectre x360 motherboard to buy from your end?
Immanuel - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 25
Altijd: 3,372
