Ga door naar hoofdinhoud
HP Spectre x360 13-4103dx Fan Replacement
Wat je nodig hebt
  1. HP Spectre x360 13-4103dx Fan Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Turn off your laptop before you start.
    • Flip your laptop so the bottom is facing upwards.
  2. HP Spectre x360 13-4103dx Fan Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #0 to remove the screws that hold the back panel down.
  3. HP Spectre x360 13-4103dx Fan Replacement: stap 3, afbeelding 1 van 1
    • Use an opening tool to remove the back panel.
    • Be careful when applying force to the panel so the components and the panel are not damaged.
    • Try to start at a corner or a place with the most room to slide under the panel.
  4. HP Spectre x360 13-4103dx Fan Replacement, Fan: stap 4, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove the screws from the fan.
  5. HP Spectre x360 13-4103dx Fan Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the group of fan wires from the motherboard.
    • Lift the fan up to remove it from the laptop.
Conclusie
Andrew Medeiros
511 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 3-6, Sinclaire Fall 2021 Lid van UMass Dartmouth, Team 3-6, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G6
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 337
