Ga door naar hoofdinhoud
HP Spectre x2 12-a002dx Screen Replacement
Wat je nodig hebt
  1. HP Spectre x2 12-a002dx Screen Replacement, Screen: stap 1, afbeelding 1 van 1
    • Make sure the device is powered off and the kick stand is retracted.
    • The HP Spectre should be placed on a flat surface with the keyboard detached.
  2. HP Spectre x2 12-a002dx Screen Replacement: stap 2, afbeelding 1 van 3 HP Spectre x2 12-a002dx Screen Replacement: stap 2, afbeelding 2 van 3 HP Spectre x2 12-a002dx Screen Replacement: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • To remove the screen, there is an entire system of clips which need to be undone as well as 4 Phillips M1.5x2.7 screws.
    • The screws should be removed using a Phillips #000 screwdriver. There is a sticker where the laptop attaches to the keyboard.
    • Heat the sticker (if needed) and use fine point tweezers to grip the sticker and remove it.
  3. HP Spectre x2 12-a002dx Screen Replacement: stap 3, afbeelding 1 van 3 HP Spectre x2 12-a002dx Screen Replacement: stap 3, afbeelding 2 van 3 HP Spectre x2 12-a002dx Screen Replacement: stap 3, afbeelding 3 van 3
    • Use the plastic opening tools or insert a spudger to begin unclipping the system.
    • Pry the screen off once all the clips have been unclipped.
    • The screen may shatter if not already shattered (beware of flying glass).
    • This screen will break. There is double tape underneath the frame, which is not listed in here.
  4. HP Spectre x2 12-a002dx Screen Replacement: stap 5, afbeelding 1 van 3 HP Spectre x2 12-a002dx Screen Replacement: stap 5, afbeelding 2 van 3 HP Spectre x2 12-a002dx Screen Replacement: stap 5, afbeelding 3 van 3
    • Remove the connecting cable of the screen and battery. Use a spudger to reveal the adhesive strip and carefully peel it off.
    • Insert a spudger to the other end and release the ZIF connectors. Detach the cable.
    • While a metal spudger is pictured, use a black nylon spudger instead because it is ESD safe.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Talha Bin Amir
683 Reputatie
5 handleidingen geschreven
USF Tampa, Team S10-G6, Thompson Fall 2017 Lid van USF Tampa, Team S10-G6, Thompson Fall 2017
USFT-THOMPSON-F17S10G6
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 4,466
