Inleiding
The touchpad is for navigating the cursor on your laptop’s screen. The touchpad may need to be replaced if there is no response when you place your hand on it. The laptop needs to be turned off and disconnected from any power source during this procedure. Disconnecting the battery while the laptop is on may hurt you or damage your laptop.
Wat je nodig hebt
Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
Orient the laptop the same way as the pictures. The battery is bordered in a red outline.
Remove the six 4 mm screws using a Phillips #000 screwdriver.
