Ga door naar hoofdinhoud
HP Spectre 13-4002dx SD Card Reader Replacement
Wat je nodig hebt
  1. HP Spectre 13-4002dx SD Card Reader Replacement, Bottom Case: stap 1, afbeelding 1 van 2 HP Spectre 13-4002dx SD Card Reader Replacement, Bottom Case: stap 1, afbeelding 2 van 2
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx SD Card Reader Replacement: stap 2, afbeelding 1 van 2 HP Spectre 13-4002dx SD Card Reader Replacement: stap 2, afbeelding 2 van 2
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx SD Card Reader Replacement, Battery: stap 3, afbeelding 1 van 3 HP Spectre 13-4002dx SD Card Reader Replacement, Battery: stap 3, afbeelding 2 van 3 HP Spectre 13-4002dx SD Card Reader Replacement, Battery: stap 3, afbeelding 3 van 3
    • Orient the laptop the same way as the pictures. The battery is bordered in a red outline.
    • Remove the six 4 mm screws using a Phillips #000 screwdriver.
  4. HP Spectre 13-4002dx SD Card Reader Replacement: stap 4, afbeelding 1 van 3 HP Spectre 13-4002dx SD Card Reader Replacement: stap 4, afbeelding 2 van 3 HP Spectre 13-4002dx SD Card Reader Replacement: stap 4, afbeelding 3 van 3
    • Do not disconnect the cable connector shown in the red box.
    • The speaker cable may be attached to the battery with black electrical tape. If so, remove the tape.
    • Move the cable clear of the battery.
  5. HP Spectre 13-4002dx SD Card Reader Replacement: stap 5, afbeelding 1 van 2 HP Spectre 13-4002dx SD Card Reader Replacement: stap 5, afbeelding 2 van 2
    • Do not disconnect the cable connector located in the red box.
    • Use tweezers to remove the speaker cable from the groove attached to the battery.
    • Push the cable to the side so it does not get in the way of the battery removal.
  6. HP Spectre 13-4002dx SD Card Reader Replacement: stap 6, afbeelding 1 van 3 HP Spectre 13-4002dx SD Card Reader Replacement: stap 6, afbeelding 2 van 3 HP Spectre 13-4002dx SD Card Reader Replacement: stap 6, afbeelding 3 van 3
    • Disconnect the battery cable connector by sliding it out of the socket.
    • Move the battery out of the way if you need more room to disconnect the power cable.
  7. HP Spectre 13-4002dx SD Card Reader Replacement: stap 7, afbeelding 1 van 1
    • Carefully remove the battery.
  8. HP Spectre 13-4002dx SD Card Reader Replacement, SD Card Reader: stap 8, afbeelding 1 van 3 HP Spectre 13-4002dx SD Card Reader Replacement, SD Card Reader: stap 8, afbeelding 2 van 3 HP Spectre 13-4002dx SD Card Reader Replacement, SD Card Reader: stap 8, afbeelding 3 van 3
    • The SD Card Port is located in the red box.
    • Remove the one PH0 30 mm screw circled in red.
  9. HP Spectre 13-4002dx SD Card Reader Replacement: stap 9, afbeelding 1 van 1
    • Remove the connector outlined in red.
  10. HP Spectre 13-4002dx SD Card Reader Replacement: stap 10, afbeelding 1 van 3 HP Spectre 13-4002dx SD Card Reader Replacement: stap 10, afbeelding 2 van 3 HP Spectre 13-4002dx SD Card Reader Replacement: stap 10, afbeelding 3 van 3
    • To unlock the ribbon cable, lift the white flap on the ZIF connector 90 degrees.
    • Slide the ribbon cable out of the connector.
  11. HP Spectre 13-4002dx SD Card Reader Replacement: stap 11, afbeelding 1 van 1
    • Remove the SD Card Port.
Conclusie
Cayce Stewart
725 Reputatie
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 241
