Ga door naar hoofdinhoud
HP Spectre 13-4002dx Display Replacement
Wat je nodig hebt
  1. HP Spectre 13-4002dx Display Replacement, Motherboard: stap 1, afbeelding 1 van 3 HP Spectre 13-4002dx Display Replacement, Motherboard: stap 1, afbeelding 2 van 3 HP Spectre 13-4002dx Display Replacement, Motherboard: stap 1, afbeelding 3 van 3
    • Remove the black tape from the motherboard.
    • Remove five screws using the Phillips #00 screwdriver that holds the motherboard in place.
    • Disconnect five ribbon cables, three power cables, and two wifi antennas from the motherboard.
    • Gently lift the motherboard out of the computer. Be careful to not to disturb the CPU fan.
    • Do not bend the motherboard.
  2. HP Spectre 13-4002dx Display Replacement, Display: stap 2, afbeelding 1 van 1
    • Remove four screws connecting the screen to the laptop case with the Phillips #00 screwdriver.
  3. HP Spectre 13-4002dx Display Replacement: stap 3, afbeelding 1 van 2 HP Spectre 13-4002dx Display Replacement: stap 3, afbeelding 2 van 2
    • Bring the laptop screen to a 270 degree angle from the base.
    • Pull the display towards you for the display to pop out of the base.
    • Gently remove the display to ensure that the cables do not get caught on the case.
  4. HP Spectre 13-4002dx Display Replacement: stap 4, afbeelding 1 van 2 HP Spectre 13-4002dx Display Replacement: stap 4, afbeelding 2 van 2
    • Remove the rubber seal around display with the opening tool.
    • Pry the display off.
    • Be careful while removing the display as it could snap and cause damage and/or injury. Be careful to not cut any wiring between the screen and its casing.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 435
