Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
The laptop needs to be turned off during this procedure. Disconnecting the battery while the laptop is powered on may hurt you or damage your laptop.
  1. Using the Torx T5 screwdriver, remove  the eight 8 mm screws on the bottom case of the laptop. Using the Torx T5 screwdriver, remove  the eight 8 mm screws on the bottom case of the laptop.
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. Pry up one corner of the bottom case  with a spudger. Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. Orient the laptop the same way as the pictures. The battery is bordered in a red outline. Remove the six 4 mm screws using a Phillips #000 screwdriver. Remove the six 4 mm screws using a Phillips #000 screwdriver.
    • Orient the laptop the same way as the pictures. The battery is bordered in a red outline.
    • Remove the six 4 mm screws using a Phillips #000 screwdriver.
  4. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  5. Do not disconnect the cable connector shown in the red box. The speaker cable may be attached to the battery with black electrical  tape. If so, remove the tape. Move the cable clear of the battery.
    • Do not disconnect the cable connector shown in the red box.
    • The speaker cable may be attached to the battery with black electrical tape. If so, remove the tape.
    • Move the cable clear of the battery.
  6. Do not disconnect the cable connector located in the red box. Use tweezers to remove the speaker cable from the groove attached to the battery.
    • Do not disconnect the cable connector located in the red box.
    • Use tweezers to remove the speaker cable from the groove attached to the battery.
    • Push the cable to the side so it does not get in the way of the battery removal.
  7. Disconnect the battery cable connector by sliding it out of the socket. Move the battery out of the way if you need more room to disconnect the power cable. Move the battery out of the way if you need more room to disconnect the power cable.
    • Disconnect the battery cable connector by sliding it out of the socket.
    • Move the battery out of the way if you need more room to disconnect the power cable.
  8. Carefully remove the battery.
    • Carefully remove the battery.
Conclusie
Cayce Stewart
725 Reputatie
6 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 24
Altijd: 481
