Ga door naar hoofdinhoud
HP Spectre 13-3010dx Charge Port Replacement
Wat je nodig hebt
  1. HP Spectre 13-3010dx Charge Port Replacement, Removal of the Back Case: stap 1, afbeelding 1 van 2 HP Spectre 13-3010dx Charge Port Replacement, Removal of the Back Case: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    Koop
    • Put on Anti Static Wrist Strap.
    • It is always a good idea to ground yourself when working with electronics to prevent static buildup. You wear this strap to protect you and your device from accidental electrostatic discharge (ESD) damage during repairs.]
    • Flip Computer Upside down.
    • Unscrew the eight 3.3mm black screws on the back casing with the T4 Torx Screwdriver.
  2. HP Spectre 13-3010dx Charge Port Replacement: stap 2, afbeelding 1 van 2 HP Spectre 13-3010dx Charge Port Replacement: stap 2, afbeelding 2 van 2
    • Use the plastic opening tool to lift the back case off.
    • Use the plastic opening tools first; metal spudgers can damage your device.
  3. HP Spectre 13-3010dx Charge Port Replacement, Battery: stap 3, afbeelding 1 van 1
    • Remove the six 2.0mm silver screws and the two 3.2 mm black screws using the PH00 Phillips Screw Head.
  4. HP Spectre 13-3010dx Charge Port Replacement: stap 4, afbeelding 1 van 1
    • Gently unplug from CONO851 plug, using the plastic opening tool.
  5. HP Spectre 13-3010dx Charge Port Replacement: stap 5, afbeelding 1 van 2 HP Spectre 13-3010dx Charge Port Replacement: stap 5, afbeelding 2 van 2
    • Gently lift up the battery and remove using the plastic opening tools.
  6. HP Spectre 13-3010dx Charge Port Replacement, Charge Port: stap 6, afbeelding 1 van 1
    • Remove the two 2.0 mm screws in the charge port bracket using the PH00 screw head.
  7. HP Spectre 13-3010dx Charge Port Replacement: stap 7, afbeelding 1 van 1
    • Use the plastic opening tools to remove the bracket.
  8. HP Spectre 13-3010dx Charge Port Replacement: stap 8, afbeelding 1 van 2 HP Spectre 13-3010dx Charge Port Replacement: stap 8, afbeelding 2 van 2
    • Lift out and disconnect the charge port.
Conclusie
4 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 11
Altijd: 6,862
