Ga door naar hoofdinhoud
HP Spectre 13 4003dx x360 Battery Replacement
Wat je nodig hebt
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Turn the computer upside down.
    • Use the T5 Torx Screwdriver to remove the eight 3.3 mm screws.
    • Make sure to use the magnetic project mat to help you keep track of the small screws.
  1. HP Spectre 13 4003dx x360 Battery Replacement: stap 2, afbeelding 1 van 2 HP Spectre 13 4003dx x360 Battery Replacement: stap 2, afbeelding 2 van 2
    • Use an opening tool to pry up and loosen the back case from the laptop.
    • If the back case doesn't loosen easily, there may be screws hidden underneath the rubber feet. Carefully pry a foot up and remove any hidden screws.
    • Remove the back case.
  2. HP Spectre 13 4003dx x360 Battery Replacement: stap 3, afbeelding 1 van 2 HP Spectre 13 4003dx x360 Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the four 2mm Phillips #00 screws securing the battery.
    • The screw locations are marked by small white arrows on the battery.
  3. HP Spectre 13 4003dx x360 Battery Replacement: stap 4, afbeelding 1 van 3 HP Spectre 13 4003dx x360 Battery Replacement: stap 4, afbeelding 2 van 3 HP Spectre 13 4003dx x360 Battery Replacement: stap 4, afbeelding 3 van 3
    • Peel off the adhesive on the left side of the battery holding the speaker wire down.
    • Move the battery slightly to gain access to the battery plug, located on the left edge of the battery.
    • Carefully unplug the battery by pulling the connector towards the battery.
    • Pull parallel to the battery, not straight up.
    • Remove the battery.
    • It is normal for your battery to flex and bend a bit where the wider section meets the narrower section.
Conclusie
For optimal performance, after completing this guide, calibrate your newly installed battery.
7 andere personen hebben deze handleiding voltooid.
Alie Antar
661 Reputatie
2 handleidingen geschreven
USF Tampa, Team S5-G4, Passmore Spring 2018 Lid van USF Tampa, Team S5-G4, Passmore Spring 2018
USFT-PASSMORE-S18S5G4
3 Leden
8 handleidingen geschreven
5 opmerkingen
I have five T4 screws that came out without issue and three that refuse to budge. Now I am trying to figure out how to remove those without damaging the laptop itself.
fxb - Antwoord
Thank you! iFixit repair kit made getting the screws out easy. Now have a renewed laptop ready with 6 plus hours of battery life.
Nicholas Steblay - Antwoord
Tutoriel parfait, excepté peut-être qu’un double-fil côté droit de la batterie doit être libéré avant de sortir la batterie.
Bravo et merci, ça m’a tout simplement permis de me dépanner seul.
FirstName LastName - Antwoord
The official HP Manual (http://h10032.www1.hp.com/ctg/Manual/c04...) mentions using Torx T5 to remove the bottom cover.
Gitesh Agarwal - Antwoord
Thanks! I will correct the step with the right screw size.
Arthur Shi -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 73
Afgelopen 30 dagen: 335
Altijd: 19,493
