Ga door naar hoofdinhoud
HP Slate 7 Extreme 4400US Top Speaker Replacement
Wat je nodig hebt
  1. HP Slate 7 Extreme 4400US Top Speaker Replacement, Back Cover: stap 1, afbeelding 1 van 3 HP Slate 7 Extreme 4400US Top Speaker Replacement, Back Cover: stap 1, afbeelding 2 van 3 HP Slate 7 Extreme 4400US Top Speaker Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
    • Once all sides have been pried up, pull the cover off and place it to the side.
  2. HP Slate 7 Extreme 4400US Top Speaker Replacement, Top Speaker: stap 2, afbeelding 1 van 2 HP Slate 7 Extreme 4400US Top Speaker Replacement, Top Speaker: stap 2, afbeelding 2 van 2
    • Use the PH #000 phillips screw bit to remove one 5.0 mm screw.
  3. HP Slate 7 Extreme 4400US Top Speaker Replacement: stap 3, afbeelding 1 van 3 HP Slate 7 Extreme 4400US Top Speaker Replacement: stap 3, afbeelding 2 van 3 HP Slate 7 Extreme 4400US Top Speaker Replacement: stap 3, afbeelding 3 van 3
    • Gently pull the entire black housing away from device.
    • Locate where the speakers' wires are connected to the motherboard.
    • Using wire cutters, sever the wires connecting the speaker to the motherboard. Strip the wires with a wire stripper and fashion the new wires to the old ones connected to the motherboard to reconnect.
    • You may use a soldering tool to disconnect the wires from the motherboard and to reconnect the new wires back to the motherboard.
Conclusie
Brandon Ko
698 Reputatie
6 handleidingen geschreven
USF Tampa, Team 11-4, Blackwell Fall 2016 Lid van USF Tampa, Team 11-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G4
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 21
Altijd: 176
