Ga door naar hoofdinhoud
HP Slate 7 Extreme 4400US Bottom Speaker Replacement
Wat je nodig hebt
  1. HP Slate 7 Extreme 4400US Bottom Speaker Replacement, Back Cover: stap 1, afbeelding 1 van 3 HP Slate 7 Extreme 4400US Bottom Speaker Replacement, Back Cover: stap 1, afbeelding 2 van 3 HP Slate 7 Extreme 4400US Bottom Speaker Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
    • Once all sides have been pried up, pull the cover off and place it to the side.
  2. HP Slate 7 Extreme 4400US Bottom Speaker Replacement, Bottom Speaker: stap 2, afbeelding 1 van 2 HP Slate 7 Extreme 4400US Bottom Speaker Replacement, Bottom Speaker: stap 2, afbeelding 2 van 2
    • Locate the wires connecting the bottom speaker to the motherboard. The wires will be running alongside the battery
    • Using the PH #000 screw bit, unscrew the two 5.0 mm screws holding the bottom speaker in place
  3. HP Slate 7 Extreme 4400US Bottom Speaker Replacement: stap 3, afbeelding 1 van 3 HP Slate 7 Extreme 4400US Bottom Speaker Replacement: stap 3, afbeelding 2 van 3 HP Slate 7 Extreme 4400US Bottom Speaker Replacement: stap 3, afbeelding 3 van 3
    • Locate where the speakers' wires are connected to the motherboard.
    • Using a pair of wire cutters, cut the wires connecting the speaker to the motherboard. Use a wire stripper to expose the wire to connect it with the wires of the new speaker.
    • You can also use a soldering tool to disconnect the wires from the motherboard and then connect the wires of the new speaker using the soldering tool.
Conclusie
Brandon Ko
698 Reputatie
6 handleidingen geschreven
USF Tampa, Team 11-4, Blackwell Fall 2016 Lid van USF Tampa, Team 11-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G4
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 22
Altijd: 161
