Ga door naar hoofdinhoud
HP Slate 7 Extreme 4400US Battery Replacement
Wat je nodig hebt
  1. HP Slate 7 Extreme 4400US Battery Replacement, Back Cover: stap 1, afbeelding 1 van 3 HP Slate 7 Extreme 4400US Battery Replacement, Back Cover: stap 1, afbeelding 2 van 3 HP Slate 7 Extreme 4400US Battery Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
    • Once all sides have been pried up, pull the cover off and place it to the side.
  2. HP Slate 7 Extreme 4400US Battery Replacement, Battery: stap 2, afbeelding 1 van 3 HP Slate 7 Extreme 4400US Battery Replacement, Battery: stap 2, afbeelding 2 van 3 HP Slate 7 Extreme 4400US Battery Replacement, Battery: stap 2, afbeelding 3 van 3
    • Cut the battery connectors one by one using wire cutters.
    • Do not cut all the wires at the same time; you risk blowing up the battery or destroying the motherboard!
    • After disconnecting the battery, take the new battery and use wire connectors to connect to the motherboard.
    • You may use a soldering tool to disconnect the wires from the motherboard, and to also soldering the wires for the replacement battery onto the motherboard.
Conclusie
Brandon Ko
698 Reputatie
6 handleidingen geschreven
USF Tampa, Team 11-4, Blackwell Fall 2016 Lid van USF Tampa, Team 11-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G4
4 Leden
16 handleidingen geschreven
Één opmerking
Dude, do you have this part? HP Slate 7 Extreme 4400CA
https://www.worthpoint.com/worthopedia/o...
sivaldodomingos - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 13
Altijd: 1,131
