Ga door naar hoofdinhoud
HP ProBook 645 Keyboard Replacement
Wat je nodig hebt
  1. HP ProBook 645 Keyboard Replacement, Remove 2 screws: stap 1, afbeelding 1 van 1
    • Remove the two screws at the two indicated locations with the phillips head screw driver.
    Vraag FixBot
    Voeg opmerking toe
  2. HP ProBook 645 Keyboard Replacement, Flip unit over and open lid.: stap 2, afbeelding 1 van 1
    • Take a spudger tool and pry the keyboard down toward the mouse pad and up toward you. After you raise the keyboard there are tabs at the bottom. Pull the keyboard away from you, and it will dislodge.
    Vraag FixBot
    Voeg opmerking toe
  3. HP ProBook 645 Keyboard Replacement, Ribbon Removal: stap 3, afbeelding 1 van 1
    • 1. Remove ribbon by flipping the black tab up and gently pulling on the ribbon.
    • 2. This ribbon has no tab, gently pull on until it comes loose. To reinsert. Line it up carefully as not to damage the ribbon, and push gently.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Doug
191 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 36
Altijd: 4,885
