Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
The battery cover is locked in place by a switch on the bottom of the laptop.
To release the lock and open the battery cover, slide the switch in the direction of the arrow next to the battery icon.
The switch marked with a padlock symbol moves back and forth freely.
The switch with the battery symbol on the other side of the battery is spring loaded, so you will have to hold it open as you remove the battery.
Slide the switch with the padlock symbol toward the unlocked side.
Insert your finger or the flat edge of a spudger into the small divot along the edge of the battery just below the battery cover lock.
Slide the spring-loaded switch with the battery symbol toward the center of the battery with one hand, while you pry the battery up with the other.
