Inleiding
Your computer’s DVD/CD drive may become damaged after prolonged use or age. One of the ways you can fix this is by replacing the drive itself.
Wat je nodig hebt
Turn the computer upside down on a flat side, so that you are seeing the underside of the laptop.
Slide the two release latches that were mentioned in the battery removal process to release the service panel.
Using a Phillips P0 Screwdriver, remove the 6 millimeter screw that secures the DVD/CD drive to the computer.
