Inleiding
The cooling fan functions to ensure that your laptop does not overheat. Since the fan runs whenever the computer is on, it is possible that it will need to be replaced or repaired at some point in time.
Wat je nodig hebt
Turn the computer upside down on a flat side, so that you are seeing the underside of the laptop.
Slide the two release latches that were mentioned in the battery removal process to release the service panel.
Using a Phillips #0 Screwdriver, remove the four Phillips 3 mm screws that secure the hard drive into the computer.
Using a Phillips P0 Screwdriver, remove the 6 millimeter screw that secures the DVD/CD drive to the computer.
Using the Torx T8 screwdriver, remove the 13 Torx 6 millimeter screws on the bottom frame of the laptop.
Using the Phillips P0 screwdriver, remove the 2 Phillips 6 millimeter screws on the bottom frame of the laptop.
Remove the 2 Phillips 3 millimeter screws from the edge of the frame where the optical drive was previously located.
Remove the 5 Phillips 3 millimeter screws from the area where the battery was previously located.
Turn the motherboard over and lay it flat so that the copper "L" is visible.
Één andere persoon heeft deze handleiding voltooid.
