Ga door naar hoofdinhoud
HP ProBook 455 G1 Battery Replacement
  1. HP ProBook 455 G1 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the computer upside down on a flat side, so that you are seeing the underside of the laptop.
    • Before removing the battery, make sure that the computer is turned off and that the power cord is not plugged into the computer.
  2. HP ProBook 455 G1 Battery Replacement: stap 2, afbeelding 1 van 1
    • Slide the two battery release latches towards the center of the laptop to release the battery.
  3. HP ProBook 455 G1 Battery Replacement: stap 3, afbeelding 1 van 2 HP ProBook 455 G1 Battery Replacement: stap 3, afbeelding 2 van 2
    • Tilt the battery upward.
    • Remove it from the laptop.
Conclusie
Jennifer Sexton
649 Reputatie
4 handleidingen geschreven
Baylor, Team S5-G1, Williams Spring 2018 Lid van Baylor, Team S5-G1, Williams Spring 2018
BU-WILLIAMS-S18S5G1
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 980
