Ga door naar hoofdinhoud
HP ProBook 4540s Keyboard Replacement
Wat je nodig hebt
  1. HP ProBook 4540s Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
    • Slide the two release latches on either side of the battery.
    • Gently tilt the battery upward and remove it from its socket.
  2. HP ProBook 4540s Keyboard Replacement, Bottom Door: stap 2, afbeelding 1 van 1
    • Turn the computer so the bottom is facing towards you.
    • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
    • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
    • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
  3. HP ProBook 4540s Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 1
    • Remove four 6.0 mm Phillips PM2.5x6.0 screws.
  4. HP ProBook 4540s Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Turn the computer over and position it right-side up in order and open the computer as far as possible.
  5. HP ProBook 4540s Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Move the keyboard in a downward fashion towards the palm rest.
  6. HP ProBook 4540s Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Lift the top of the keyboard at an angle and then gently pull it up and away from the palm rest.
    • Only pull the keyboard up enough to release it. The cable beneath the keyboard will still be attached to the system board.
  7. HP ProBook 4540s Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the keyboard cable by lifting the latch at the center of the system board.
    • Completely remove the keyboard.
Conclusie
15 andere personen hebben deze handleiding voltooid.
Amber Schindler
1.027 Reputatie
6 handleidingen geschreven
UW Tacoma, Team 1-5, Rose Fall 2016 Lid van UW Tacoma, Team 1-5, Rose Fall 2016
UWT-ROSE-F16S1G5
4 Leden
2 opmerkingen
Precise and clear guide. Great Work!!!
Mario Mutale - Antwoord
Easy to follow and a great help to get the job done. Thanks
d1211109 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 34
Altijd: 7,093
