Ga door naar hoofdinhoud
HP ProBook 4540s Back Door Replacement
Wat je nodig hebt
  1. HP ProBook 4540s Back Door Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
    • Slide the two release latches on either side of the battery.
    • Gently tilt the battery upward and remove it from its socket.
  2. HP ProBook 4540s Back Door Replacement, Bottom Door: stap 2, afbeelding 1 van 1
    • Turn the computer so the bottom is facing towards you.
    • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
    • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
    • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Amber Schindler
1.027 Reputatie
6 handleidingen geschreven
UW Tacoma, Team 1-5, Rose Fall 2016 Lid van UW Tacoma, Team 1-5, Rose Fall 2016
UWT-ROSE-F16S1G5
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 22
Altijd: 2,032
